[Qgis-user] In: wps plugin problem
José Carlos Martínez Llario jomarlla at cgf.upv.es
Wed Sep 10 04:37:51 PDT 2014
Hi Samanta.
This is the same error I get when I try to connect from QGIS to my local
GeoServer WPS Service.
I coulnt make QGIS WPS client work with GeoServer.
The last time I sent a post to this list (several months ago) the
conclusion was that currently is not possible to connect QGIS WPS Plugin
with Geoserver WPS.
Hope someone can help us now.
Cheers,
Jose
On 10/09/2014 13:33, Samanta.Biasiolli at sinergis.it wrote:
> Hi,
> I have a problem with wps plugin, this are the steps that I execute:
> 1) I create my connection at my local Geoserver
> 2) I choose a wps (for example gs:Count, by Geosolution)
> 3) I execute the wps
> The response is:
> Traceback (most recent call last):
>   File
> "C:\Users\a2sb0132/.qgis2/python/plugins\wps\wpslib\executionresult.py",
> line 129, in resultHandler
>     self.parseResult(resultXML)
>   File
> line 202, in parseResult
>     statusXML = pystring()
> TypeError: pystring() takes exactly 1 argument (0 given)
> do you have any ideas for my problem?
> The versions that I use are:
> Python version:
> 2.7.5 (default, May 15 2013, 22:44:16) [MSC v.1500 64 bit (AMD64)]
> QGIS version:
> 2.0.1-Dufour Dufour, d94c044
> Wps-plugin: 2.0.9 Date: 2014-06-25
> Any suggestion?
> thank you
> Le informazioni contenute in questo messaggio di posta elettronica
> sono riservate e confidenziali e ne e' vietata la diffusione in
> qualsiasi modo o forma. Qualora Lei non fosse la persona destinataria
> del presente messaggio, La invitiamo a non diffonderlo e ad
> eliminarlo, dandone gentilmente comunicazione al mittente.
> The information included in this e-mail and any attachments are
> confidential and may also be privileged. If you are not the correct
> recipient, you are kindly requested to notify the sender immediately,
> to cancel it and not to disclose the contents to any other person.
> Die Informationen in dieser E-Mail-Mitteilung sind vertraulich und
> deren Verbreitung in jeglicher Art oder Form ist untersagt. Sollten
> Sie diese Nachricht irrtümlich erhalten haben, ersuchen wir Sie,
> sofort den Absender darüber zu informieren und die Mail zu löschen.
> /http://www.dedagroup.it/
> Qgis-user mailing list
http://cartosig.upv.es
Producción Cartográfica y SIG.
Dpto. Ingeniería Cartográfica.
Univ. Politécnica de Valencia.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140910/a9083563/attachment.html>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140910/a9083563/attachment.gif>
