[Qgis-user] Rif: Re: In: wps plugin problem
José G Moya Y. josemoya at gmail.com
Wed Sep 10 05:43:22 PDT 2014
I think this is similar to a bug I notified earlier in july. There was a
very obvious bug inside the python file and I tried to change it, but It
did not compile. I will look inside my files.
2014-09-10 14:28 GMT+02:00 Salvatore Larosa <lrssvtml at gmail.com>:
> Hi,
> On Wed, Sep 10, 2014 at 2:04 PM, <Samanta.Biasiolli at sinergis.it> wrote:
>> Thank you very much, for your reponse,
>> My colleague opened a ticket on their redmine too (
>> http://hub.qgis.org/issues/11178) and I hope someone can help us.
> this is a specific issue for the WPS plugin, so you should file a ticket
> to the correct bug tracker [0] in order to warn the maintainer.
> Also, should be helpful adding a sample URL to test.
> Regards,
> -SL
> [0] - http://hub.qgis.org/projects/qgswps
> Salvatore Larosa
> linkedIn: http://linkedin.com/in/larosasalvatore
> twitter: @lrssvt
> skype: s.larosa
> IRC: lrssvt on freenode
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140910/7f534c3e/attachment.html>
