[Qgis-user] R: Re: How to import a Google map
labiancamarilena at libero.it labiancamarilena at libero.it
Wed Sep 10 06:56:06 PDT 2014
Hello,
today I saw a tutorial where the author sayd that it's better to save the map as kml file, but when I try to save the map (edited by my colleague in google maps) I don't see any button o comand.
----Messaggio originale----
Da: sig.upagu at gmail.com
Data: 10/09/2014 14.40
A: "labiancamarilena at libero.it"<labiancamarilena at libero.it>
Cc: "qgis-user at lists.osgeo.org"<qgis-user at lists.osgeo.org>
Ogg: Re: [Qgis-user] How to import a Google map
Hi Marilena:
In Google Earth, you must save your "place" as kml file.
In QGIS you can open directly this KML. If you want edit it, then save this KML file as a new SHP file.
Good luck
Carlos Cerdán
2014-09-10 5:30 GMT-05:00 labiancamarilena at libero.it <labiancamarilena at libero.it>:
my colleague has done a map indicating some points
using google maps.
I would like to import into Qgis.
How can I do? Is there a plugin?
thanks
Marilena
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140910/4664baa4/attachment.html>
