[Qgis-user] In: wps plugin problem
Salvatore Larosa lrssvtml at gmail.com
Wed Sep 10 07:07:26 PDT 2014
Hi José,
On Wed, Sep 10, 2014 at 1:37 PM, José Carlos Martínez Llario <
jomarlla at cgf.upv.es> wrote:
> Hi Samanta.
> This is the same error I get when I try to connect from QGIS to my local
> GeoServer WPS Service.
> I coulnt make QGIS WPS client work with GeoServer.
> The last time I sent a post to this list (several months ago) the
> conclusion was that currently is not possible to connect QGIS WPS Plugin
> with Geoserver WPS.
I don't know if the WPS client plugin works fine with a Geoserver WPS URL,
I never tried it, but looking at the code, if that piece of code is running
then it was throwing some error from WPS server side, I guess.
I changed the source code so I can see the error and avoid the pystring
exception.
Before I submit the patch I would like to test with a Geoserver WPS URL,
Could anyone share any Geoserver WPS URL?
Salvatore Larosa
linkedIn: http://linkedin.com/in/larosasalvatore
twitter: @lrssvt
skype: s.larosa
IRC: lrssvt on freenode
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140910/22b2f04a/attachment.html>
