[Qgis-user] Fwd: Error in Photo2shape using mac
Emiliano Manzo
emiliano.manzo at ethoikos.it
Mon Sep 22 03:10:14 PDT 2014
Hi to everybody
> I found an error when i tried to select output browse using plugin Photo2Shape
> Here there is the error code
> Thank you
Greetings from italy
> Emiliano
> Errore durante l'esecuzione di codice Python:
> Traceback (most recent call last):
> File "/Users/emilianomanzo/.qgis2/python/plugins/photo2shape/photo2shapedialog.py", line 102, in selectOutputFile
> TypeError: QgsEncodingFileDialog(QWidget parent=None, QString caption=QString(), QString directory=QString(), QString filter=QString(), QString encoding=QString()): argument 3 has unexpected type 'QPyNullVariant'
> Versione Python:
> 2.7.5 (default, Mar 9 2014, 22:15:05)
> [GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
> Versione di QGIS:
> 2.4.0-Chugiak Chugiak,
> Percorso Python: ['/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing', '/Users/emilianomanzo/.qgis2/python/plugins/sextante_animove', '/Applications/QGIS.app/Contents/MacOS/../Resources/python', u'/Users/emilianomanzo/.qgis2/python', u'/Users/emilianomanzo/.qgis2/python/plugins', '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins', '/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.7', '/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7', '/Library/Python/2.7/site-packages/numpy-override', '/Library/Python/2.7/site-packages/matplotlib-override', '/Library/Frameworks/GDAL.framework/Versions/1.11/Python/2.7/site-packages', '/Library/Frameworks/cairo.framework/Versions/1/Python/2.7', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC', '/Library/Python/2.7/site-packages', '/Library/Python/2.7/site-packages/PIL', '/Users/emilianomanzo/.qgis2/python/plugins/MetaSearch/ext-libs', '/usr/share/qgis/python', '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools']
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140922/bca83aef/attachment.html>
