[Qgis-user] Labels not visible when setting them programmatically.
Werner Macho
werner.macho at gmail.com
Wed Apr 1 05:20:48 PDT 2015
hmm -
well - as the qchainage plugin clearly sets labeling (when enabled)
you could take it and search for the missing piece..
regards
Werner
On Wed, Apr 1, 2015 at 2:19 PM, Casper Børgesen (CABO) <CABO at niras.dk> wrote:
> No the triggerRepaint() didn't work, just to clarify that I tried that :)
> Regards, Casper
> -----Original Message-----
> From: Werner Macho [mailto:werner.macho at gmail.com]
> Sent: 1. april 2015 13:52
> To: Casper Børgesen (CABO)
> Cc: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Labels not visible when setting them programmatically.
> Hi!
> I thought maybe it is the
> triggerRepaint()
> but it was just a guess.
> regards
> Werner
> On Wed, Apr 1, 2015 at 1:48 PM, Casper Børgesen (CABO) <CABO at niras.dk> wrote:
>> Hi Werner
>> Sadly no, it does not.
>> Regards, Casper
>> Sent: 1. april 2015 13:43
>> Hi,
>> does
>> https://github.com/mach0/qchainage/blob/master/chainagetool.py
>> line 150 ff help you?
>> regards
>> Werner
>> On Wed, Apr 1, 2015 at 1:25 PM, Casper Børgesen (CABO) <CABO at niras.dk> wrote:
>>> I’m trying to programmatically set and enable labelling on a layer
>>> using Python in QGis 2.9.0.
>>> label = QgsPalLayerSettings()
>>> label.readFromLayer(myLayer)
>>> label.enabled = True
>>> label.fieldName = 'myField'
>>> # Just to change something clearly visible.
>>> label.textColor = QColor(255,0,0,255)
>>> label.writeToLayer(myLayer)
>>> This doesn’t enable labelling, but if I enter the Layer Properties on
>>> myLayer, everything looks okay and when pressing Apply, the labels
>>> become visible.
>>> Is there something I need to set to avoid having to manually click
>>> Apply to get the labels visible?
>>> Calling iface.mapCanvas().refresh() afterwards doesn’t work.
>>> Regards, Casper
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
