[Qgis-user] After upgrade none of the TIFF imagery is visible
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Fri Apr 24 07:24:46 PDT 2015
Did someone help you on this?
I am Not sure why the raster would not show up? Right click a layer ad select zoom to layer extant. Can you see it?m if not, click the layer property and change the way the raster is rendered (min max). If it does not work, send an old project file with a few of the rasters. I will look at them.
Grass, saga and the rest are other Gis programs. Qgis lacks some analysis tools so rather than making everything from scratch, they make ports to other programs. Don't remove then. One day you will be stuck with a problem and see that Grass or SAGA has a good algorithm!
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
www.archeotec.ca
On Apr 22, 2015 7:18 PM, "jon-2 [via OSGeo.org]" <ml-node+s1560n5202562h83 at n6.nabble.com> wrote:
I was using QGIS 1.8 and upgraded to 2.8.1. When I open an old Project,
the image layers are present in the list on the left, but none of the
imagery is visible on the map. Not sure how to bring the imagery back.
Also, I'm overwhelmed by all of the programs that were installed: Grass,
Desktop, Browser, SAGA. Is there a brief description explaining which
to use under various circumstances?
Thanks!
Jon
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/After-upgrade-none-of-the-TIFF-imagery-is-visible-tp5202562.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/After-upgrade-none-of-the-TIFF-imagery-is-visible-tp5202562p5202854.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150424/4554a344/attachment.html>
