[Qgis-user] Georeferencing Vector Files
Springfield Harrison stellargps at gmail.com
Sun Aug 9 00:08:00 PDT 2015
Right, but where is org2org?  I've looked in many menu items, help,
etc. to no avail.
Sorry to be a bit thick but how is it accessed?
Also, GRASS has v.transform and v.rectify but starting a new GRASS
mapset fails with no reason given.
Great tools but why are they so hard to access?
         Thanks, cheers . . . .   Spring Harrison
At 08-08-2015 23:20 Saturday, Alex Mandel wrote:
>Save the whole map, it's on the main File menu, it just saves the
>current canvas.
>If you already have a list of gcps you can skip that step
>Example
>http://gis.stackexchange.com/questions/107298/process-to-georeference-corners-of-vector-file
>Enjoy,
>Alex
>On 08/08/2015 07:26 PM, Springfield Harrison wrote:
> > Hello Alex,
> >        Further to my last, for Vector Save As, I couldn't find any
> > option to save it as a raster file. Is there some other place to look?
> >                Thanks again, Cheers . . . . . . . . Spring Harrison
> > At 08-08-2015 12:07 Saturday, Alex Mandel wrote:
> >> On 08/06/2015 11:08 AM, Springfield Harrison wrote:
> >> > Hello All,
> >> > Is there a tool/plugin for georeferencing vector files to an existing
> >> > projected layer?
> >> > I'm intending to bring in property survey drawings that have only local
> >> > coordinates but projected coordinates (UTM) are available for some
> >> corners.
> >> > Thank you . . . .
> >> > Cheers . . . . . Springfield Harrison
> >> > Samsung Tab 4
> >> My trick, is convert the vector an image in QGIS (Save Image)
> >> Georeference the image, saving the control point list out to a file.
> >> You can then use these control points (gcps) with ogr2ogr to transform
> >> the original vector.
> >> -Alex
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
