[Qgis-user] Cumulative count cut on rasters
Andrea Peri
aperi2007 at gmail.com
Wed Aug 12 06:07:48 PDT 2015
Hi Radim, thx for explain.
Your explanation of extimated strategy could explain why the extimated
is more precise rather than the actual strategy.
I guess are the null values to produce a wrong "actual" results.
Can you say me in which file I can found the code for the extimate and
actual strategy
to verify my hypotesis.?
Thx.
2015-08-12 11:22 GMT+02:00 Radim Blazek <radim.blazek at gmail.com>:
> On Tue, Aug 11, 2015 at 3:09 PM, Andrea Peri <aperi2007 at gmail.com> wrote:
>> Hi,
>> trying the rendering of a raster floating point using the cumulative count cut.
>> I see it is quite good if I set the values 2.0,100.0% (not 98%) and
>> use the accuracy at value "estimate".
>> Instead always with the same values for cumulative count cut, but
>> using the accuracy "actual".
>> The result is really poor. The image became totally black with only
>> few isles of grey.
>> This is a surprise for me because the accuracy "actual" take a long
>> time and the name seem to say more precision.
>> I like to know what is the strategy used for actual: estimate and the
>> strategy for accuracy: actual.
> Actual takes all pixels, estimate takes 250000 pixels (whole data
> extent with resolution giving approximately 250000 pixels). Some
> providers may use different approach to get estimated values, e.g.
> GDAL provider may use approximated values returned by GDAL, IIRC.
> Radim
>> Many thx.
>> Andrea Peri
>> qwerty àèìòù
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Andrea Peri
qwerty àèìòù
