[Qgis-user] QGis server project files stored in DB?
Andrea Peri aperi2007 at gmail.com
Wed Aug 12 06:13:41 PDT 2015
I don't guess is more flexible.
Infact usually the teting environment is never exactly exals to the
publish environmnet.
A file allw to open and correct the paths from develop and publish environment.
Also the svg symbols could be not exactly with the same path from
So having a same project in a db is more complex becasue need to have
two environment exactly the same.
And this is not possible.
I guess the db storing for project could be more flexible only if the
paths to the layers and relative paths of svg was not stored in the
project file but instead in other files.
My 2ct.
A.
2015-08-12 15:06 GMT+02:00 lars lingner <gislars+list at gmail.com>:
> Hello,
> I'm looking for a solution for storing QGis project files (qgs) in a
> PostgreSQL database. Storing the files in a table isn't actually the
> problem, but getting it out and feeding it to QGis server.
> Did anyone had this need already? Would this be a good idea?
> In my use case the project files are generated, based on a default
> project file. Having the file in the DB would give more flexibility.
> Since saving the style in DB is already supported by QGis, I'm just
> curious of opinions of other users or developers.
> Thanks in advance for any feedback
> Lars
> Qgis-user mailing list
Andrea Peri
qwerty àèìòù
