[Qgis-user] Point data to polygon
McDonaldR McDonaldR at angus.gov.uk
Mon Aug 17 06:13:01 PDT 2015
Hello Strumbi
You want to do a spatial join.  However, you may run into problems if there is more than one point per polygon but it sounds as though there is a one-to-one relationship between them.
In QGIS do Vector > Data Management Tools > Join Attributes By Location
Target is the polygon layer
Join layer is the points
Hope that helps
Ross
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Velizar Strumberger
Sent: 17 August 2015 11:01
To: Qgis-user at lists.osgeo.org
Subject: [Qgis-user] Point data to polygon
HI
I have a layer with points that have over 50 attributes. I have a layer with polygons (one attribute)  and each point is in the boundaries of one polygon. How can I transfer the data from the points to the polygons.
Thank you (if you can help)
Regards
Strumbi
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons. Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150817/5ac04f86/attachment.html>
