[Qgis-user] DXF Export issue
Russell Fincher russell_sp01 at rfincher.com
Mon Aug 17 16:02:18 PDT 2015
Greetings! First post here.
I'm having trouble successfully exporting to DXF. These are my steps:
   1. In QGIS, choose Layer>Add Layer>Add Raster Layer
   2. I select an .lbl file next to an associated .img file that I got from
   the Mola Mars data here
   <http://pds-geosciences.wustl.edu/mgs/mgs-m-mola-5-megdr-l3-v1/mgsl_300x/meg128/>
   3. A height map successfully appears in the viewer window.
   4. I choose Project>DXF Export and leave the settings at default.
   5. I get an exported DXF, but it is basically empty. 16 kb and only 2700
   lines of what mostly looks like header data. I'm unable to import it into
   3ds Max, getting an error on import about an incorrect sequence.
These three files can be downloaded here
<https://drive.google.com/file/d/0B65j6EIp4zMQVzExQy1sWFVsOWs/view?usp=sharing>
if anyone wants to look at them.
Any ideas what I'm doing wrong?
- Russell
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150817/82f9dd15/attachment.html>
