[Qgis-user] Dimension feature using QGIS Wien
Enrique filonio at gmail.com
Tue Aug 18 03:20:35 PDT 2015
Same error.
I'm not a python expert  :-(  but I think there are extra brackets after
QgsMapLayerRegistry:
File ...plugins/dimensioning/tools/utils.py, line 35:
QgsMapLayerRegistry().instance().addMapLayer(vl, True)
Should be:
QgsMapLayerRegistry.instance().addMapLayer(vl, True)
I think there are some issues with the reference system of the dimension
lines, but I haven't investigated yet...
Enrique.
2015-08-18 9:57 GMT+02:00 Paolo Cavallini <cavallini at faunalia.it>:
> Il 18/08/2015 09:23, Franco Cazzola ha scritto:
> > Iam looking forwardto the problem to add *dimension feature* to Qgis
> “Wien”
> > -       Using dimension plugin in Qgis;
> > I am not able to insert “selected two vertex points” (first icon of
> > plugin); are there any setting or prerequisites to use it ? I tried also
> > creating a SpatiaLite database …. resultles
> Hi Franco,
> I'm able to select the two points from a shapefile, but then I get an
> error:
> https://github.com/kalxas/dimensioning/issues/1
> Anyone confirms?
> All the best.
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150818/d3f4dfa5/attachment.html>
