[Qgis-user] QGIS 2.10.1 adding PostGIS Views
Luca Lanteri mescal72 at gmail.com
Mon Aug 31 12:00:15 PDT 2015
I noticed that this new behavior has been backported to 2.8.3.
I think this behavior should be considered a regression because now it's
very uncomfortable to load views, specially when I have to load many views.
I also noticed that lot of users are confused, because they thinks that
views doesn't work. I think the old behavior was better because it allowed
both to choose a custom gid and to load view faster.
Currently we decide to remain with 2.8.2.
What about reconsidering to return to the old behavior ?
Thanks
Luca
2015-08-06 20:58 GMT+02:00 Jürgen E. <jef at norbit.de>:
> Hi Randal,
> On Thu, 06. Aug 2015 at 13:53:08 -0400, Randal Hale wrote:
> > In 2.8.x I can add the view and the Primary key is automatically
> displayed.
> No, you're supposed to select the primary key.  In 2.8.x you also have to
> choose from all columns, but first one is preselected.  If that happens to
> be
> the primary key, you're fine, but that's not always the case and hence
> newer versions force you to actually select it.
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel.
> +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax.
> +49-4931-918175-50
> Software Engineer           D-26506 Norden
> http://www.norbit.de
> QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150831/a727da40/attachment.html>
