[Qgis-user] [Processing] error updating "Processing"
Victor Olaya volayaf at gmail.com
Thu Dec 3 04:23:56 PST 2015
I don't see that line with the wrong import in the current code, so
this is likely to be fixed. Maybe it is still wrong in the last
published version, so in case it's there we will release a new version
in the plugin server
hope this helps
2015-12-03 11:03 GMT+01:00 Alessio Degioannini <a.degioannini at proterstudio.com>:
> Hi, I asked the same question (see attached message), but no one has replied
> Alessio
> Il 03/12/2015 09:13, skampus ha scritto:
>> hi, i have some installation of qgis on my windows 8.
>> I installed via osgeo4w:
>> 2.8.4-2 (LTR dev)
>> 2.12.1-1 (Lyon)
>> 2.13.0-21 (dev)
>> but there is a problem with the update processing.
>> In fact, if I upgrade it to 2.12.2 from 2.10.99, a directory called
>> "processing" is created in C:\ Users\ ... \. qgis2\python\ plugins folder
>> and this error comes out:
>> Couldn't load plugin 'processing'
>> ImportError: cannot import name spatialite_utils
>> Traceback (most recent call last):
>>    File "C:/OSGeo4W/apps/qgis/./python\qgis\utils.py", line 281, in
>> loadPlugin
>>      __import__(packageName)
>>    File "C:/OSGeo4W/apps/qgis/./python\qgis\utils.py", line 572, in
>> _import
>>      mod = _builtin_import(name, globals, locals, fromlist, level)
>>    File "C:/Users/11186cs/.qgis2/python/plugins\processing\__init__.py",
>> line
>> 29, in
>>      from processing.tools.general import *
>> _import
>>    File
>> "C:/Users/11186cs/.qgis2/python/plugins\processing\tools\general.py",
>> line 28, in
>>      from processing.core.Processing import Processing
>> _import
>>    File
>> "C:/OSGeo4W/apps/qgis/./python/plugins\processing\core\Processing.py",
>> line
>> 40, in
>>      from processing.core.GeoAlgorithm import GeoAlgorithm
>> _import
>>    File
>> "C:/OSGeo4W/apps/qgis/./python/plugins\processing\core\GeoAlgorithm.py",
>> line 41, in
>>      from processing.core.parameters import ParameterRaster,
>> ParameterVector,
>> ParameterMultipleInput, ParameterTable, Parameter
>> _import
>>    File
>> "C:/OSGeo4W/apps/qgis/./python/plugins\processing\core\parameters.py",
>> line
>> 33, in
>>      from processing.tools.vector import resolveFieldIndex, features
>> _import
>>    File
>> "C:/Users/11186cs/.qgis2/python/plugins\processing\tools\vector.py",
>> line 20, in
>>      from processing.algs.qgis import spatialite_utils
>> Python version: 2.7.4 (default, Apr  6 2013, 19:54:46) [MSC v.1500 32 bit
>> (Intel)]
>> QGIS version: 2.12.1-Lyon Lyon, 16760fd
>> at this point, it no longer works neither processing nor any plugins
>> associated (processing_workflow, and so on).
>> The only solution is to delete the directory called "processing", but that
>> processing is outdated.
>> is this a bug?
>> thanks a lot
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/Processing-error-updating-Processing-tp5239778.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> ---------- Mensaje reenviado ----------
> From: Alessio Degioannini <a.degioannini at proterstudio.com>
> To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> Cc:
> Date: Wed, 18 Nov 2015 14:05:05 +0100
> Subject: [Qgis-user] 2.12.0-Lyon - Error on updating Processing
> Hi,
> attached the error report in object.
> Thanks in advance.
> Alessio
