[Qgis-user] QGIS project slow to open when too much wms layers
Andrea Peri
aperi2007 at gmail.com
Sat Dec 5 16:01:07 PST 2015
For who is interest to test the opening issue on wms layer.
This is the link to retrieve the porject I'm using.
It is a project for qgis 2.12 using only wms layers.
The time to open is about 7 minutes.
https://www.dropbox.com/s/he85dwlluvcv4rw/wms_project.zip?dl=0
A.
2015-12-05 23:58 GMT+01:00 aperi2007 <aperi2007 at gmail.com>:
> Hi,
> I try to change the qgis project setting for the wms url the parameter:
> "Ignore GetMap/GetTitle URI reported in capabilities"
> But the sniffer report me that the qgis is still doing the getcapabilities
> request at start of project.
> If the getcapability reported url is to be ignored , why it is still calling
> the getcapabilities at startup ?
> A.
> Il 05/12/2015 23:45, aperi2007 ha scritto:
> Hi Jurgen,
> I know that the getmap url, getfeatureinfo ulr and getlegendgraphics url
> couldbe significative different from the main url for the getcapability
> request.
> But when choose the layer I guess in the project was stored the three url.
> Infact I see in the setting windows for new wms service is available the
> option
> This mean that if I choose this option , it should avoid to read and parse
> the getcapabilities url to retrieve the urls and this also mean (i guess)
> that the url stored are the direct url for
> getmap/getlegendgraphics/getfeatureinfo not for the getcapabilities.
> I check in the qgis project and I'm not able to understand if the url used
> is for the getcapabilites or for the getmap request.
> Infact our project use the same url for all.
> <datasource>crs=EPSG:3003&dpiMode=all&featureCount=10&format=image/png&layers=r_toscan_cst_fogli&styles=&url=http://www502.regione.toscana.it/wmsraster/com.rt.wms.RTmap/wms?map%3Dwmscastore</datasource>
> <datasource>crs=EPSG:3003&format=image/png&layers=lett_c_aree_tutelate&styles=default&url=http://www502.regione.toscana.it/wmsraster/com.rt.wms.RTmap/wms?map%3Dwmspiapae%26version%3D1.3.0%26map_resolution%3D91%26map_mnt%3Dfotovolt</datasource>
> A.
> Il 05/12/2015 23:00, Jürgen E. Fischer ha scritto:
> Hi Andrea,
> On Sat, 05. Dec 2015 at 21:34:10 +0100, Andrea Peri wrote:
> But when I open a project where the wms layer are just added why do a
> getcapabilites request for every wms layer in it ?
> The capabilities provide the urls for all the other requests (sometimes
> pointing to other servers and sometimes even wrong - hence the ignoreUrl
> options).
> Jürgen
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Andrea Peri
qwerty àèìòù
