[Qgis-user] Break a line up into lines of equal segments
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Mon Dec 7 07:50:28 PST 2015
Not sure but I would take a file and densify the geometry
(vector/Geometry tools/Densify geometries.) My GUESS is that the added
vertex are equally spaced.  Then you could open the processing toolbar
and search for Explode line.  If this is like Autocad, it will break up
the line at every vertex.  This methods, though, will give different
results based on the line length and the original number of vertex....
:( I would test before using this method.
You could probably handle the problem with more precision using a python
script... There could be other solutions out there.
Good luck
Nicolas
Le 2015-12-07 09:45, Leahy, Thomas A. [via OSGeo.org] a écrit :
>                Hello,
>         Is there a way to draw a line and then break it up into equal
> segments?
>              Best Regards,
>              Tom
> Qgis-user mailing list
> [hidden email] </user/SendEmail.jtp?type=node&node=5240282&i=0>
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> If you reply to this email, your message will be added to the
> discussion below:
> http://osgeo-org.1560.x6.nabble.com/Break-a-line-up-into-lines-of-equal-segments-tp5240282.html
> To start a new topic under Quantum GIS - User, email
> ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==>.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Break-a-line-up-into-lines-of-equal-segments-tp5240282p5240293.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151207/14620b79/attachment.html>
