[Qgis-user] how to get rid of points and only show labels?
Basques, Bob (CI-StPaul)
bob.basques at ci.stpaul.mn.us
Tue Dec 8 09:24:00 PST 2015
Ok, but now I’m at a loss as to why there is a SYMBOL on/off button in the first place.
shrinking the symbol to nothing also works.
bobb
On Dec 8, 2015, at 11:14 AM, McDonaldR <McDonaldR at angus.gov.uk<mailto:McDonaldR at angus.gov.uk>> wrote:
Hi Bob
Yeah, there is work being done on making the UI UX better at the moment so this might get in.
The label is part of the style hence the disappearance when the symbol is turned off. Your best bet then is to set the label style and set the symbol style transparency to 100%. Bit clunky but will give the look you are after.
Ross
From: Basques, Bob (CI-StPaul) [mailto:bob.basques at ci.stpaul.mn.us]
Sent: 08 December 2015 17:07
To: McDonaldR
Subject: Re: [Qgis-user] how to get rid of points and only show labels?
Ross,
Well that’s intuitive (NOT!). should have guessed it was something like that, especially as a long time Mac user. :c)
Thanks. That was it, sort of, now the label goes away when I click the symbol off . . . I’m labeling from an Attribute column.
bobb
Looking for this type of label (see the point in there, I set them back up to a size from the previous “zero” value in order to see the setting take effect), but the label goes bye-bye when I click the symbol off. :
<image002.png>
On Dec 8, 2015, at 10:55 AM, McDonaldR <McDonaldR at angus.gov.uk<mailto:McDonaldR at angus.gov.uk>> wrote:
Ah ok
So double click the first rule.
A new window pops up to let you define the rule.
The check box is on that window.
Let me know if that works
Ross
Sent: 08 December 2015 16:54
To: McDonaldR
Cc: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Here are the settings before I change to Rule-Based . . .
<image001.png>
And then after . . .
<image002.png>
Thanks
bobb
On Dec 8, 2015, at 10:21 AM, McDonaldR <McDonaldR at angus.gov.uk<mailto:McDonaldR at angus.gov.uk>> wrote:
Odd
I am running 2.8.3 and the option is there. But I am running on Windows. Might be different to Mac OSX. I can check in an hour or so when I am out of the office.
<image001.png>
-----Original Message-----
Sent: 08 December 2015 15:57
To: McDonaldR
Ok, I’m in Rule-based, and still don’t see the Symbol check box.
(2.8.1 Mac OS)
bobb
> On Dec 8, 2015, at 3:54 AM, McDonaldR <McDonaldR at angus.gov.uk<mailto:McDonaldR at angus.gov.uk>> wrote:
> Hi Bob, Burghardt
> You have to change the symbol style to "rule based" and then there is the option to turn off the symbol for the point. The option is not available when using a point styled with "single symbol"
> Regards
> Ross
> From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf
> Of Burghardt.Scholle at stadt.wolfsburg.de<mailto:Burghardt.Scholle at stadt.wolfsburg.de>
> Sent: 08 December 2015 07:51
> To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
> Hi Andreas,
> hm, in which QGIS-Version you have made this screenshot :-)? I work with QGIS 2.12.1, where it can't find that option button.
> Burghardt
> -----Ursprüngliche Nachricht-----
> Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag
> von Andreas Neumann
> Gesendet: Dienstag, 8. Dezember 2015 08:20
> An: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
> Betreff: Re: [Qgis-user] how to get rid of points and only show labels?
> Hi Bob,
> It is much easier - you don't have to fuss around with zero size or transparency.
> Just uncheck the "Symbol" checkbox and your symbol will disappear. See attached screenshot.
> Andreas
> On 08.12.2015 00:17, Donovan Cameron wrote:
>> Yes, one way can be done with a style trick by setting the size of
>> the point symbol to 0.
>> Donovan
>> On 07/12/15 04:09 PM, Basques, Bob (CI-StPaul) wrote:
>>> All,
>>> What should I even be looking for in the user manual as far as a key
>>> word to search on?
>>> I want to get rid of (make disappear in QGIS) the points I’m
>>> labeling. I have eat label working just fine, but I want to not
>>> display the point. Do I need to fake the styling to do this, or??
>>> Thanks
>>> bobb
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons. Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
> <qgis_pt_symbol.jpg>_______________________________________________
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151208/c4e1adc4/attachment.html>
