[Qgis-user] postgis/gresql views
Brent Wood pcreso at yahoo.com
Wed Dec 9 08:36:39 PST 2015
Hi Matt,
What is the actual SQL you use to create the view?Something like:create view v_geo asselect tab1.location,       tab1.zone,       tab1.date,       tab1.value,       tab2.geomfrom tab1, tab2where tab1.location=tab2.location;
Then do a
select * from v_geo order by location, zone, date;
To check the records are as expected, before you try to open in QGIS. Also note that ideally you should include a integer primary key to clearly identify each record uniquely.
eg:
alter table tab1 add column id serial primary key;and include this id column in the view.
You have not described the relationship between zones & locations. My assumption would be that locations are point features & zones represent polygons that the locations lie within, but this doesn't make sense with your example - "for all zones in location"
It is also unclear whether you want to view categorised data in QGIS, or create Postgis views in Postgis from QGIS:"Ideally I'd like to be able to create labels and views from within qgis ..."
Unless I understand your problem better, I can't offer useful advice.
Cheers
Brent Wood
 To: qgis-user <qgis-user at lists.osgeo.org>
 Sent: Wednesday, December 9, 2015 7:08 PM
 Subject: [Qgis-user] postgis/gresql views
Hi QGISers.I'm trying to work out how to display some geological data on map.Basically Table x; location1 | zone1 | date1 | value1location1 | zone1 | date2 | value2continued with variations in location/zone etc..
spatial table geometry Column | location1
I create a view in postgresql using the location as the common column. However, when I try to display my data, zone2 is shown with value1 and I can't work out how to get 2 values and 2 zones to display at a time.
All the data is there and shown correctly in the combined attributes table, however labels don't show correctly.
Ideally I'd like to be able to create labels and views from within qgis using functions (eg, for all zones in location1, what is the sum of the values).
I've only been at this a couple of hours this afternoon but thought I'd check here in case there's a simpler solution than the one I'm heading towards.
ThanksMatt
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151209/64f79382/attachment.html>
