[Qgis-user] rotating labels from attribute, how to use 0-360 (in place of -180 - 180)
Jonathan jonathan-lists at lightpear.com
Wed Dec 9 12:28:29 PST 2015
Hi Bob,
   Using QGIS 2.8.3, and I'm guessing you're referring to symbol
rotation, the range is 0 to 360 degrees.
If you want to use an attribute, you can easily do on-the-fly
calculations by clicking on the little symbol to the right of "Angle"
box, and selecting "Edit". Use this expression builder to set the
expression you want to be used for calculating your symbols rotation.
See also: http://nathanw.net/2011/10/27/expression-based-labeling/
Cheers,
Jonathan
On 08/12/2015 22:13, Basques, Bob (CI-StPaul) wrote:
> All,
> So it looks like QGIS is expecting rotation values as -180 - 180.  How do I change this to 0 - 360?  I’m exporting the numbers from a CAD (AutoCAD) program.  I may be able to tweak the output from AutoCAD to get the expected rotation, but is there a way to change the rotation limit values in QGIS on the fly via an expression?
> Thanks
> bobb
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
