[Qgis-user] Esri file geodatabase into spatiallite to be edited
Lene Fischer lfi at ign.ku.dk
Wed Dec 9 22:46:09 PST 2015
Hi Randal and Donovan,
Thanks for your answers. I´ll look into the solutions later today.
Regards
Lene
-----Oprindelig meddelelse-----
Fra: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] På vegne af Donovan Cameron
Sendt: 10. december 2015 00:41
Til: qgis-user at lists.osgeo.org
Emne: Re: [Qgis-user] Esri file geodatabase into spatiallite to be edited
Hey Lene,
And if you wanna get command line crazy, ogr2ogr, a utility from GDAL can do the conversion in one step but like Randal said, subtypes and domains are lost (these can be converted to tables from ArcGIS if available and joined later in QGIS).
ogr2ogr --config OGR_SQLITE_SYNCHRONOUS OFF \ --config OGR_SQLITE_CACHE 1024 \ -progress \ -gt 65536 \ -a_srs "EPSG:123456" \ -f SQLite output.sqlite input.gdb \ -dsco SPATIALITE=YES \ -lco FORMAT=SPATIALITE \ -nlt PROMOTE_TO_MULTI \ -dim 2
OK. So some notes on the above command!
You will want to change the -a_srs to an EPSG the FileGDB data is actually in (this "assigns" the projection, and doesn't actually re-project/transform the data). Sometimes its usually safe to even exclude this all together but you have to check the data in the output spatialite database, after it's been imported to see if the projection was assigned properly - so I include it from the get to so I don't have to re-upload if there are errors.
The -nlt option can be changed to the actual geometry type of the data (ie, POINT vs MULTIPOINT). Currently it just imports all geospatial data as a multi-type feature because RDBMS have strict checks for geometry - the lazy mans way.
You can also remove the -dim option if you have some 3D geometries, otherwise I use it when geometries have no Z-Value.
Any questions, let me know.
Donovan
On 09/12/15 11:52 AM, Randal Hale wrote:
> You could open the File Based Geodatabase with the openfileGDB driver
> and save one of the feature classes to a Spatialite database. You can
> use the DB Manager to import the rest of the layers. It seems to work
> pretty well.
> If the FileBasedGeodatabase has relations/subtypes/domains etc those
> won't be pulled over.
> I wouldn't be surprised if there was a one line gdal command to move
> it all at once.
> Anyway, my .02 cents worth. Good Luck!
> Randy
> On 12/09/2015 01:20 PM, Lene Fischer wrote:
>> Hi,
>> I got a question today from a user in Iceland:
>> is it possible to import esri file geodatabase into spatiallite to be
>> edited?
>> I know nothing about this - does any of you cleaver people :-)
>> Regards
>> Lene Fischer
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Kind regards,
Donovan
