[Qgis-user] QGIS Error
Richard Mwangi richiemwesh at gmail.com
Fri Dec 11 01:26:01 PST 2015
Hi There,
Im using Qgis 2.12 and whenever i try to overlay my polygons using any of the open layer maps, i.e. google, bing and apple maps it gives me a python error. the error is
n error has occured while executing Python code:
QgsCsException: forward transform of (14038.328034, 174195.093236) PROJ.4:  +proj=longlat +datum=WGS84 +no_defs +ellps=WGS84 +towgs84=0,0,0 +to  +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs Error: latitude or longitude exceeded limits
  File "/Users/richie/.qgis2/python/plugins/openlayers_plugin/weblayers/weblayer.py", line 97, in addLayer
    self._addLayerCallback(self)
  File "/Users/richie/.qgis2/python/plugins/openlayers_plugin/openlayers_plugin.py", line 135, in addLayer
    self.setMapCrs(coordRefSys)
  File "/Users/richie/.qgis2/python/plugins/openlayers_plugin/openlayers_plugin.py", line 176, in setMapCrs
    extMap = coordTrans.transform(extMap, QgsCoordinateTransform.ForwardTransform)
Python version: 2.7.10 (default, Aug 22 2015, 20:33:39) [GCC 4.2.1 Compatible Apple LLVM 7.0.0 (clang-700.0.59.1)]
QGIS version: 2.12.0-Lyon Lyon, exported
Python Path:
/Users/richie/.qgis2/python/plugins/processing
/Applications/QGIS.app/Contents/MacOS/../Resources/python
/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins
/Library/Frameworks/SQLite3.framework/Versions/C/Python/2.7
/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7/site-packages
/Library/Python/2.7/site-packages/numpy-override
/Library/Python/2.7/site-packages/matplotlib-override
/Library/Frameworks/MapServer.framework/Versions/6.0/Python/2.7
/Library/Frameworks/GDAL.framework/Versions/1.11/Python/2.7/site-packages
/Library/Frameworks/cairo.framework/Versions/1/Python/2.7
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC
/Users/richie/.qgis2//python
/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools
Has any one come across this error? How do you fix the error.
Thanks.
Richard.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151211/2fbaafba/attachment.html>
