[Qgis-user] Restoring Items Tab in Upper Panel of Print Composer
Anita Graser
anitagraser at gmx.at
Sun Dec 13 08:31:42 PST 2015
On Sun, Dec 13, 2015 at 3:51 PM, Philip Condit <philipmcondit at gmail.com>
wrote:
> I'm just getting started using QGIS. I'm trying to make a map of Japan
> using the QGIS Tutorial. When I open the Print Composer, there is no Items
> tab in the upper panel. There is a Command history tab, but no Items tab.
> If I go to View > Panels, only 4 options are shown: Composition, Item
> properties, Command history, and Atlas generation. There is no option
> shown for Items. All of the 4 options have a check mark in their box, so
> they are all active in the Print Composer window. How can I restore the
> Items tab to the upper panel of the Print Composer?
Just to make sure: which version of QGIS do you use?
Best wishes,
Anita
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151213/e3a68921/attachment.html>
