[Qgis-user] R and GRASS integration in QGis
pisquerra pisquerra at gmail.com
Mon Dec 14 00:26:08 PST 2015
Thanks Matteo,
I had been trying several times to set the folder and the path both for R
and GRASS trough the options in Processing menu.
I have also deisntallled and installed again Qgis and GRASS, but that doesn't
work either.
Best wishes,
2015-12-11 11:24 GMT+01:00 Matteo Ghetta <matteo.ghetta at gmail.com>:
> Mostly the problems are related to the PATHs
> did you have a look here?
> http://docs.qgis.org/testing/en/docs/user_manual/processing/3rdParty.html#a-note-for-windows-users
> Cheers
> Matteo
> 2015-12-11 9:15 GMT+01:00 pisquerra <pisquerra at gmail.com>:
>> Hello,
>> I have problems trying to use R and GRAS in Qgis 2.12.0 Lyon in Windows.
>> When I try to call this programs in Qgis an error message appears telling
>> the dependencies are not satisfied. There seem to be a problem with the
>> path but I can't fix it.
>> Has anyone had this same problem? How could you solve it?
>> Thank you very much for your attention and help.
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151214/4a30833c/attachment.html>
