[Qgis-user] extracting elevations from DEM at certain points
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Wed Dec 16 06:19:14 PST 2015
The point sampling tools works very well. All you need is to import your xyz points into QGIS using the CSV import tools. With that, you can import your points and then save them as a shape file. I don't think the sampling tool works with CSV layers.
Once you have this shape file, make sure it is in the same projection as the raster (as extra precaution). Then, use the point sampling tool to sample your points. You can get raster values or even vector values if your point falls within a polygon. This tools works well with thousands of points...
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
www.archeotec.ca
On Dec 16, 2015 02:41, "Siki Zoltan [via OSGeo.org]" <ml-node+s1560n5241526h67 at n6.nabble.com> wrote:
Dear Szilard,
there is a point sampling plugin for QGIS:
https://plugins.qgis.org/plugins/pointsamplingtool/ Regards,
Zoltan
On Wed, 16 Dec 2015, Szilard Albert wrote:
> Hello,
> I need to extract elevation values from a DEM at certain points for which I
> have X and Y values.
> My points are contained in several profiles, each profile with hundreds of
> points.
> My input is a text file, one file per profile, with the following format:
> PointA X Y
> PointB X Y
> PointZ X Y.
> I would like a solution where I can feed the above text input, and get my
> output as another text file
> with similar format, Point X Y Z (or Point Z X Y). Alternatively just a
> text file with one column containing Z,
> but exactly same number of rows, so I can copy and paste to the input.
> One single command that solves one point only would do as well, I would
> just create a script file from my every
> text file for every line....
> Any suggestions would be greatly appreciated.
> I am using QGIS 2.8 Wien in Ubuntu.
> Thank you.
> Szilard
Qgis-user mailing list
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/extracting-elevations-from-DEM-at-certain-points-tp5241513p5241526.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/extracting-elevations-from-DEM-at-certain-points-tp5241513p5241601.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151216/da456b28/attachment-0001.html>
