[Qgis-user] FileGDB: missing FID column
James Wood jwood911 at gmail.com
Wed Dec 16 08:42:59 PST 2015
That's interesting Thomas. Hadn't really noticed that before, but when I add in feature classes in the same manner, I can see the OBJECTID for some but not others. Seems random at the moment...
James
> Date: Wed, 16 Dec 2015 14:04:51 +0100
> From: t.schuettenberg at mailbox.org
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] FileGDB: missing FID column
> Hi!
> please can anybody tell me why the FID column of a fileGDB-Layer is ignored and not shown in QGIS?
> I added a fileGDB via add vector layer>directory>type OpenFileGDB or ESRI-FileGDB and everything
> works fine and fast.
> But when looking at the attribute table or the layer propeties the column "objectid" is not there
> although it is part of the data (see ogrinfo below). I tested this with 2.8.4 and 2.12.1
> The actual reason to fumble with the FileGDB is, that i want to transfer this data to my PG. In this
> import process (e.g. OGR processing "Import Vector into PostGIS database") however the FID column is
> also ignored.
> A (new) FID/PK-column, that can be created during import is always filled with fresh serial values -
> not the original IDs from the data source -even when their name are the same.
> The only way I see to solve / by-pass this (in my use case) is to duplicate the objectids to a new,
> seperate field befor doing the ogr-import.
> But maybe some of you could suggest a better solution (and save me from the manual
> table-editing-pain? ;-)
> thanks in advance
> Thomas
> C:\Windows\System32>ogrinfo -so c:\zeug\kanal_end.gdb KaAnschlusspunkt
> Had to open data source read-only.
> INFO: Open of `c:\zeug\kanal_end.gdb'
>       using driver `OpenFileGDB' successful.
> Layer name: KaAnschlusspunkt
> Geometry: Point
> Feature Count: 3377
> Extent: (8.300000, 11.186000) - (371550.148000, 5663269.606000)
> Layer SRS WKT:
> PROJCS["ETRS89 / UTM zone 32N",
>     GEOGCS["ETRS89",
>         DATUM["European_Terrestrial_Reference_System_1989",
>             SPHEROID["GRS 1980",6378137,298.257222101,
>                 AUTHORITY["EPSG","7019"]],
>             TOWGS84[0,0,0,0,0,0,0],
>             AUTHORITY["EPSG","6258"]],
>         PRIMEM["Greenwich",0,
>             AUTHORITY["EPSG","8901"]],
>         UNIT["degree",0.0174532925199433,
>             AUTHORITY["EPSG","9122"]],
>         AUTHORITY["EPSG","4258"]],
>     PROJECTION["Transverse_Mercator"],
>     PARAMETER["latitude_of_origin",0],
>     PARAMETER["central_meridian",9],
>     PARAMETER["scale_factor",0.9996],
>     PARAMETER["false_easting",500000],
>     PARAMETER["false_northing",0],
>     UNIT["metre",1,
>         AUTHORITY["EPSG","9001"]],
>     AXIS["Easting",EAST],
>     AXIS["Northing",NORTH],
>     AUTHORITY["EPSG","25832"]]
> FID Column = OBJECTID
> Geometry Column = Shape
> PunktNr: String (0.0)
> Punktkennung: String (0.0)
> Kanalart: String (0.0)
> QGIS-DE e.V. | http://qgis.de
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151216/23f6c8a6/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151216/23f6c8a6/attachment.png>
