[Qgis-user] Field Calculator
DelazJ delazj at gmail.com
Thu Dec 17 03:54:24 PST 2015
It might just be hidden by the two other panels. At the middle right side
of the Expression tab, you should have a kind of anchor (with a vertical
dotted line on Windows ) you can use and pull to the left to resize
Functions list and let the help appear.
FYI, Field calculator dialog looks like this now (
https://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/field_calculator.html#figure-attributes-3
2015-12-17 11:49 GMT+01:00 Martin Bittens <martin.bittens at gmx.de>:
> Hello QGIS-Users
> I am running the QGIS 2.13.0-Master (32bit) on a Windows 7 machine. The
> problem I am not able to solve is the following: the field calculator does
> not display the "Selected Function Help" window. It was there in one of the
> previous QGIS versions, but now it got lost. Any ideas how to solve that
> problem?
> Thanks a lot
> Martin
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151217/af4939c5/attachment.html>
