[Qgis-user] Projection like Google Earth?
Joris Hintjens jorishin at gmail.com
Thu Dec 17 04:30:34 PST 2015
Thanks Paolo and Alex.
Alex: I remember now that I had installed Globe plugin, but (on my mac) it crashes. SO I threw it away.
For now, I can see no advantage inWorldwind, compared to G.E.
The link Paolo send, is very interesting. I played with it and came to a certain level of satisfaction. I realize now that, for creating a map that you can pan and tilt around endlessly, as you can in Google earth, one would have to adapt the projection wit every pan/tilt of the map. Maybe some day, when I am older and wiser, I’ll find a solution in a script/plugin.
My aim is to make a web-based map with my data in (pseudo) 3D. For now, I’ll have to export to GoogleEarth.
Have fun!
Joris
> Op 16 dec. 2015, om 18:39 heeft Paolo Craveri <pcraveri at gmail.com> het volgende geschreven:
> Hi Joris
> 2015-12-16 17:11 GMT+01:00 Joris Hintjens <jorishin at gmail.com <mailto:jorishin at gmail.com>>:
> Is it possible to create a map like the globe in Googel earth, where the map is an infinite that can be turned around instead of panned?
> AFAIK I think not, unless you use globe plugin
> is is a question of the right projection?
> Yes, azimuth orthographic projections  is a suitable projection for making ''globe''  like Google earth.
> take a look at this:
> http://polemic.nz/2014/11/21/nz-azimuth-orthographic/ <http://polemic.nz/2014/11/21/nz-azimuth-orthographic/>
> I've just tried the proposed python script; It works perfectly!
> ciao
> Paolo Craveri
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151217/d77f3df7/attachment.html>
