[Qgis-user] Looking for a suggestion on a vector format
Basques, Bob (CI-StPaul) bob.basques at ci.stpaul.mn.us
Fri Dec 18 09:06:52 PST 2015
Hi Jesse,
I’ve actually done work in this area as well.  After reading your needs list and before seeing that you thought about DWG/SVG, I’ll say that those were the two formats I was going to suggest for storing everything.  DXF is open, as well as DWG (More work though).
You might be able to make a case for GeoJSON, but it’s limiting in some ways, and you would probably need to include JS or a JS Lib as well as the styling info separately.  Although you could conceivably put it all into a single HTML doc.
bobb
On Dec 18, 2015, at 8:14 AM, Jesse McGraw <jlmcgraw at gmail.com<mailto:jlmcgraw at gmail.com>> wrote:
All,
  Before I go too far down the wrong path perhaps you can help me with a suggestion on a vector format to use for a project of mine:
I'm to looking to basically re-create various Instrument Approach Procedure plates (see here<http://aeronav.faa.gov/d-tpp/1513/00375il28r.pdf> for an example for San Francisco International - SFO ) from a database via a perl script and display a number of them as vector overlays in an existing QGIS project
What would be a good format to use for this purpose?
I'm imagining something like a QGIS project file, but I want it to contain to contain all of the various bits of information internally (coordinates, names, styling, icons etc.) and not have to query anything external so each file is a stand-alone unit.
Ideally all of the coordinates would be real world lon/lat so no transformation would be required.  Bonus points if the format is openly standardized and easy to work with
DWG/DXF?  SVG?
Thanks,
  Jesse
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151218/2acd919d/attachment.html>
