[Qgis-user] Google with OTF - as XML
Andreas Neumann a.neumann at carto.net
Sun Dec 20 05:41:51 PST 2015
Hi Lene,
Yes - the Google images are quite up-to-date in my region as well.
Definitely a big plus.
Andreas
On 20.12.2015 11:48, Lene Fischer wrote:
> Hi Andreas, Nyall and Paolo,
> I´m well aware of all these incidents. I just had a urgent need for
> getting the newest Ortophoto for a specific area. And Google did have
> one from summer 2015. My drone recording went wrong and I had a
> deadline. So Google saved my day. The print scale was 1:2000 and was OK.
> My drone ortho is normally much better J - 2 cm pixel gives a
> brilliant map.
> But still the OpenLayer Plugin give me a lot of trouble…. CRS and OTF
> crash.
> Regards
> Lene
> *Fra:*Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *På vegne
> af *Andreas Neumann
> *Sendt:* 20. december 2015 09:19
> *Til:* qgis-user at lists.osgeo.org
> *Emne:* Re: [Qgis-user] Google with OTF - as XML
> Hi,
> From a technical point of view it seems to work. But as Nyall said,
> you are not allowed to use Google tiles directly and print out your
> own layers on top of it. For that reason we can't add any Google
> layers to QGIS - officially.
> I tried it out - for aerial images the reprojection works fine (if one
> also uses bilinear/cubic/average interpolation) - but the maps with
> lineart and labels look really, really ugly after they had been
> reprojected.
> If you print out at high resolution - again the aerial images look
> fine, but the higher you increase the resolution, the thinner the road
> symbology gets and the roads get labeled way too often - so not very
> pretty from a (carto)-graphical point of view. I was impressed though
> that you can also print at very large sizes (I tested an A0 map wirh
> my layers and Google images in the backdrop - it took very long to
> render, but it worked). If you use this too often, there is also the
> risk that Google blocks your IP address.
> The Swiss OSM association offers tiles in the native Swiss projection.
> This allows to print much nicer maps than with Google maps. See
> http://sosm.ch/swiss-lv95-projected-tiles/ and you can use the
> attached xml file to open as a raster image. I think it would be a
> good idea if other national OSM associations would offer their data in
> the native national coordinate system. Something to discuss with your
> local OSM gurus ...
> The nice thing about this tile-map GDAL provider is that you can
> manipulate the raster on the fly (e.g. convert it to black and white,
> make it darker or lighter, change contrast or colors globally, etc.)
> Andreas
> On 20.12.2015 00:34, Lene Fischer wrote:
>     Hi,
>     Just got a small Christmas present from my husband. 6 XML files  :-)
>     Containing Google and Streetview. And then you might say 'Yeah we already got that in OpenLayer Plugin' - Correct. But when I use OpenLayer, the vector layers always fly around and calculations mess up.
>     So now I got the XML files.
>     Renamed to Zip and Unzipped the files. Open as Raster.
>     They are now changed in the 'On The Fly' - in any CRS I want.
>     Now I´m looking forward to my real Christmas Present - Hope Bo read this mail so he don´t forget  ;-)
>     Regards
>     Lene Fischer
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     List info:http://lists.osgeo.org/mailman/listinfo/qgis-user
>     Unsubscribe:http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151220/1f783e61/attachment.html>
