[Qgis-user] Grass 7 vectors via browser?
Radim Blazek radim.blazek at gmail.com
Mon Dec 21 10:09:04 PST 2015
On Mon, Dec 21, 2015 at 3:04 PM, knussear <knussear at mac.com> wrote:
> It says ": topology version 7"
Then you are running the plugin version 6, look into
Help > About > Providers > Available QGIS Data Provider Plugins
which version is listed. If it is available for your distribution,
install the plugin version 7.
You can also check in Log Messages Panel > Plugins if the plugin
version 7 is already installed but does not load, in that case
LD_LIBRARY_PATH or PATH does not contain path to the correct GRASS
version libraries.
Radim
> Opens in Grass just fine. I have tried v.build and then it will display, but
> it frequently crashes QGIS to do so.
> <http://osgeo-org.1560.x6.nabble.com/file/n5242313/QGIS_2_12_1-Lyon.png>
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Grass-7-vectors-via-browser-tp5242070p5242313.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
