[Qgis-user] node tool zoom problem
Wannes De Crop
Wannes.DeCrop at UGent.be
Thu Feb 5 01:11:27 PST 2015
Hi Nathan,
Normally I have it set to pixels. It does not seem to have anything to
do with those settings, since changing anyting there has no effect on
it. Also it does work in 1.7.0 with the same snapping settings.
Cheers,
Wannes
Citeren Nathan Woodrow <madmanwoo at gmail.com>:
> Wannes,
> You should check your snapping settings in Settings -> Snapping. You might
> have it set to map units which means as you zoom out it becomes smaller
> because it's using real distance vs pixels which are constant.
> - Nathan
> On Wed Feb 04 2015 at 8:13:07 PM Wannes De Crop <Wannes.DeCrop at ugent.be>
> wrote:
>> Hi,
>> It has been a while since I used QGIS so about 2 weeks ago I installed
>> 2.6.1 (on Windows 7 Home Premium, 64 bits). For the last couple of
>> days I've been working on a shapefile. Yesterday morning I try to
>> continue, add feature works fine, but when I zoom in and try to adjust
>> some nodes using the node tool I get this message "Node tool: could
>> not snap to a segment on the current layer.". I frantically click
>> around and notice that is does work when I'm more zoomed out (which is
>> of course completely useless in this case). I've tried different
>> settings, new projects and shapefiles and deleted and reinstalled QGIS
>> 2.6.1, but no luck there. I still have an old version of QGIS (1.7.0)
>> as well where the node tool works fine with the same settings. Any
>> ideas?
>> Cheers,
>> Wannes
>> Wannes De Crop
>> Ghent University
>> Department of Biology, Research Group Limnology
>> K.L. Ledeganckstraat 35
>> B - 9000 Ghent Belgium
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Wannes De Crop
Ghent University
