[Qgis-user] dxf2shp - keep property
Basques, Bob (CI-StPaul)
bob.basques at ci.stpaul.mn.us
Thu Feb 5 07:41:23 PST 2015
If you have AutoCAD Map, you can export with any of the feature properties included in the export as feature attributes.
Bobb
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Nicolas Cadieux
Sent: Thursday, February 05, 2015 5:52 AM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] dxf2shp - keep property
I know you can export those properties in columns if you export from AutoCAD.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
Le 2015-02-05 02:49, "Torsten Lange-2 [via OSGeo.org] " <[hidden email]</user/SendEmail.jtp?type=node&node=5185704&i=0>> a écrit :
Does anyone knows a workaround that keeps feature properties of a dxf-file?
Specifically, I have isolines with a property "elevation" that is to keep for labeling purpose in the map. Dxf2shp plugin, as well as Grass v.in.dxf and Saga dxf modules seem not to provide this functionality.
Thank you, Torsten
Qgis-user mailing list
[hidden email]</user/SendEmail.jtp?type=node&node=5185641&i=0>
http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/dxf2shp-keep-property-tp5185641.html
To start a new topic under Quantum GIS - User, email [hidden email]</user/SendEmail.jtp?type=node&node=5185704&i=1>
To unsubscribe from Quantum GIS - User, click here.
NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: Re: dxf2shp - keep property<http://osgeo-org.1560.x6.nabble.com/dxf2shp-keep-property-tp5185641p5185704.html>
Sent from the Quantum GIS - User mailing list archive<http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150205/07715a0c/attachment.html>
