[Qgis-user] dxf2shp - keep property
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Thu Feb 5 13:30:38 PST 2015
In my humble opinion AutoCAD Map is neither an engineering nor geological solution...
Nicolas
Le 2015-02-05 14:01, "Torsten Lange-2 [via OSGeo.org] " <ml-node+s1560n5185823h74 at n6.nabble.com> a écrit : If we had, I could probably use AutoCAD Map, but we don't have it, because geological surveys are not supposed to use engineering solutions ;) Torsten Am 05-Feb-2015 17:16:37 +0100 schrieb [hidden email] :
<blockquote style="border-left:2px solid #CCCCCC;padding:0 1em" style="margin-left: 0; padding-left: 5px; border-left: 2px solid navy;">
If you have AutoCAD Map, you can export with any of the feature properties included in the export as feature attributes.
Bobb
From: [hidden email] [mailto: [hidden email] ] On Behalf Of Nicolas Cadieux Sent: Thursday, February 05, 2015 5:52 AM To: [hidden email] Subject: Re: [Qgis-user] dxf2shp - keep property
Hi, I know you can export those properties in columns if you export from AutoCAD.
Nicolas Cadieux M.Sc. Les Entreprises Archéotec inc. 8548, rue Saint-Denis Montréal H2P 2H2 Téléphone: 514.381.5112 Fax: 514.381.4995
Le 2015-02-05 02:49, "Torsten Lange-2 [via OSGeo.org] " < [hidden email] > a écrit :
Hi, Does anyone knows a workaround that keeps feature properties of a dxf-file? Specifically, I have isolines with a property "elevation" that is to keep for labeling purpose in the map. Dxf2shp plugin, as well as Grass v.in.dxf and Saga dxf modules seem not to provide this functionality. Thank you, Torsten _______________________________________________ Qgis-user mailing list [hidden email] http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/dxf2shp-keep-property-tp5185641.html
To start a new topic under Quantum GIS - User, email [hidden email] To unsubscribe from Quantum GIS - User, click here . NAML
View this message in context: Re: dxf2shp - keep property Sent from the Quantum GIS - User mailing list archive at Nabble.com.
[hidden email]
http://osgeo-org.1560.x6.nabble.com/dxf2shp-keep-property-tp5185641p5185823.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/dxf2shp-keep-property-tp5185641p5185844.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150205/ab627c2b/attachment.html>
