[Qgis-user] qgis shape files modified - arcview shows old
Alexandre Neto
senhor.neto at gmail.com
Fri Feb 6 03:16:39 PST 2015
Can you try delete all files except the SHP, DBF, SHX and PRJ before open
it in ArcGIS?
I think I already had this problem and that's how I have solved it.
By that time, I got the impression that ArcGIS create some kind of cache
files to improve the reading on shapefiles. This files are not updated by
QGIS and therefore the change became not visible back in ArcGIS.
Hope it helps,
Alexandre Neto
On Fri, Feb 6, 2015 at 10:24 AM, Torsten Lange <torsten.lange at mail.de>
wrote:
> Hi,
> For a specific purpose we rely on an Arcview plugin. If I open shape files
> in Arcview that where modified in Qgis I always see the version from befor
> it was modified. So, as a workaround I save the file to a new shape file,
> then every thing is ok. ArcGis doesn't show this odd behavior.
> Why is that? Is there any option to keep the shape files clean? I'm
> afraid, one time I could forget to save as new file and reload, which - if
> work proceeds - leads to cumbersome extra work.
> Thanks, Torsten
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150206/a7cc3e5b/attachment.html>
