[Qgis-user] How to install MrSid plugin on Mac
William Kyngesburye
woklist at kyngchaos.com
Thu Feb 12 16:34:24 PST 2015
Nice that they gave you a link to the old version.
1. That's when you double click the disk image file, it's assuming you are installing the SDK immediately after installing the plugin, so the disk image should still be open. After a coule days, you probably ejected it.
2/3. Terminal is in Utilities, and type (or copy-paste) exactly as in the readme.
On Feb 12, 2015, at 6:01 PM, Steven Yanoff <yanoff at tularosa.net> wrote:
> FYI I obtained SDK 9.0 per below.
> I installed the MrSid GDAL plugin from your website, and the SDK, copying files per your Readme. Your Readme then says "Now the main library needs to be updated. The MRSID GDAL Plugin disk image must be open, ie don't put it away after installing the plugin. Type the following in a Terminal and press Return, enter admin password when asked:
> sudo "/Volumes/MrSID GDAL Plugin/install tools/install_name_tool" -change libtbb.dylib @loader_path/libtbb.dylib "/Library/Application Support/GDAL/1.11/Libraries/libltidsdk.9.dylib"
> I will ask for some help.
> 1. What do you mean "the MRSID GDAL Plugin disk image must be open"? How do I do that?
> 2. Do I just open Terminal from Utilities?
> 3. Do I type exactly the above, including sudo, and the quotes?
> Sorry to ask these basic questions but I am not familiar with this.
> Steven Yanoff
> Begin forwarded message:
>> From: sdksupport <sdksupport at lizardtech.com>
>> Subject: RE: General Info - question about which SDK to download for Mac OS X 10.75
>> Date: February 12, 2015 2:58:50 PM MST
>> To: Steven Yanoff <yanoff at tularosa.net>
>> We do have a version 9.0 SDK available here:
>> https://s3.amazonaws.com/bin.us.lizardtech.com/download/developer/MrSID_DSDK-9.0.0.3864-darwin11.universal.gccA42.tar.gz
>> Regards,
>> SDK Support
>> -----Original Message-----
>> From: Steven Yanoff [mailto:yanoff at tularosa.net]
>> Sent: Wednesday, February 11, 2015 7:12 PM
>> To: sdksupport
>> Subject: Re: General Info - question about which SDK to download for Mac OS X 10.75
>> Is there a place to download SDK's for 10.7.5? I understand what you say that you have moved on to 10.8 and 10.9, but it would be very helpful for those that have not upgraded.
>> Steven Yanoff
> On Feb 11, 2015, at 5:54 PM, William Kyngesburye wrote:
>> Unless you can get LizardTech to make older versions of the SDK available (ie you need 9.0, the current is 9.1), I think you're out of luck. You may be lucky with the with the latest for OS X 10.8, but don't count on it.
>> I'll have to update the plugin with the new minimum OS X. I'll probably also soon have to bump the minimum for all my packages since Apple isn't supporting 10.7 any more (that is, no security updates).
>> On Feb 11, 2015, at 1:28 PM, yanoff at tularosa.net wrote:
>>> Hi,
>>> Installing the MrSid plugin for QGIS 2.06 on a Mac also requires installing
>>> the SDK from LizardTech (https://www.lizardtech.com/developer/). This is
>>> explained in the Readme that accompanies the MrSid plugin, at
>>> http://www.kyngchaos.com/software/frameworks#gdal_complete.
>>> However, my Mac runs OS X 10.7.5, and the SDKs now available from LizardTech
>>> are for OS X 10.8 and 10.9. In an email response, LizardTech said it no
>>> longer supports pre-10.8 Mac OS.
>>> Any idea what to do? Should I still go ahead and try installing the MrSid
>>> plugin with SKD for 10.8?
>>> Thanks!
>>> Steven Yanoff
>>> View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-install-MrSid-plugin-on-Mac-tp5186932.html
>>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
>> Second Pogril: I don't know. Why IS life like sticking your head in a bucket filled with hyena offal?
>> First Pogril: I don't know either. Wretched, isn't it?
>> -HitchHiker's Guide to the Galaxy
"The beast is actively interested only in now, and, as it is always now and always shall be, there is an eternity of time for the accomplishment of objects."
- the wisdom of Tarzan
