[Qgis-user] Displaying 16 bit per channel images
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Fri Feb 13 17:42:11 PST 2015
3 options I think.
1: http://docs.qgis.org/2.6/en/docs/user_manual/introduction/getting_started.html#command-line-options. This will permit you to set the resolution.
2: you can save the image using the map printing utility.
3: I think you can save a raster as an image file somewhere. Maybe under raster or something.... Can't remember were exactly....
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
Le 2015-02-13 15:37, "Gabriel Lema [via OSGeo.org]" <ml-node+s1560n5187531h22 at n6.nabble.com> a écrit :
Hello,
I was wondering what QGIS does to display 16 bit per channel RGB
images. I would like to covert them to 8 bit per channel normal PNG or
JPG image, but when I save it using the "Save as..." in the "Project"
menu, I get a low resolution image.
If I could have access to the conversion from 16 bit to 8 bit that
QGIS does, which makes a good looking RGB image, I could do that same
conversion on any other software, and save it full resolution. Is it a
gamma correction? I've tried many different, but haven't been
successful so far.
If I save it using gdal_translate I get a greenish looking image, that
is very different from the good looking image that QGIS displays.
Thank you for your help.
Gabriel
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Displaying-16-bit-per-channel-images-tp5187531.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Displaying-16-bit-per-channel-images-tp5187531p5187564.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150213/b0bf9046/attachment.html>
