[Qgis-user] Strange behaviour importing data from postgis
Igor Sosa Mayor
joseleopoldo1792 at gmail.com
Mon Feb 23 01:25:31 PST 2015
I'm starting using QGIS and I found a strange behaviour importing a
layer from postgis.
I'm doing the following:
1. download from openstreetmap a osm file
2. import it to postgis with osm2psql
3. I add a layer in QGIS using the postgresql import function.
Everything seems to work OK...
BUT: not all points are imported. More or less 30% out of the points is
not neither in the layer nor in the attribute table. But if I do a query
on the database the points are there.
Maybe any idea how I could debug this a little better (without error
messages it is difficult to see the possible issue)...
Many thanks in advance.
:: Igor Sosa Mayor :: joseleopoldo1792 at gmail.com ::
:: GnuPG: 0x1C1E2890 :: http://www.gnupg.org/ ::
:: jabberid: rogorido :: ::
