[Qgis-user] QGIS 2.6.1 on Centos 6.5
Paolo Corti
pcorti at gmail.com
Thu Feb 26 02:34:49 PST 2015
Hi all
I would need to have QGIS 2.6.1 working in Centos 6.5, and I am trying
to build it, but I am struggling at the same point hit by other users
with Debian 6 [1]:
[clipped]
[ 8%] Building CXX object
src/core/CMakeFiles/qgis_core.dir/qgsvectorlayerfeatureiterator.cpp.o
/home/test/software/qgis/QGIS/src/core/qgsvectorlayerfeatureiterator.cpp:
In constructor ‘QgsVectorLayerFeatureIterator::QgsVectorLayerFeatureIterator(QgsVectorLayerFeatureSource*,
bool, const QgsFeatureRequest&)’:
/home/test/software/qgis/QGIS/src/core/qgsvectorlayerfeatureiterator.cpp:87:
error: class ‘QgsVectorLayerFeatureIterator’ does not have any field
named ‘QgsAbstractFeatureIteratorFromSource’
/home/test/software/qgis/QGIS/src/core/qgsvectorlayerfeatureiterator.cpp:88:
error: no matching function for call to
‘QgsAbstractFeatureIteratorFromSource<QgsVectorLayerFeatureSource>::QgsAbstractFeatureIteratorFromSource()’
/home/test/software/qgis/QGIS/src/core/qgsfeatureiterator.h:113: note:
candidates are: QgsAbstractFeatureIteratorFromSource<
<template-parameter-1-1> >::QgsAbstractFeatureIteratorFromSource(T*,
bool, const QgsFeatureRequest&) [with T = QgsVectorLayerFeatureSource]
/home/test/software/qgis/QGIS/src/core/qgsfeatureiterator.h:111: note:
QgsAbstractFeatureIteratorFromSource<QgsVectorLayerFeatureSource>::QgsAbstractFeatureIteratorFromSource(const
QgsAbstractFeatureIteratorFromSource<QgsVectorLayerFeatureSource>&)
At global scope:
/home/test/software/qgis/QGIS/src/core/qgsvectorlayerfeatureiterator.cpp:521:
warning: unused parameter ‘methodType’
I have upgraded gcc to 4.7.2 version, but still no joy here.
Some more information on the non standard Centos 6.5 dependencies 9
(compiled from sources) I am using:
QT 4.7.2
SIP 4.13.3
PyQT 4.9.4
QScintilla 2.8.4
GDAL 1.11.2
Anyone can give a good recommendation about what is the cleanest way
to build on Centos 6.5?
Are you aware of any package created for it even only for test?
thanks a lot
p
[1] http://osgeo-org.1560.x6.nabble.com/Compiling-QGIS-2-4-with-GCC-4-4-debian-squeeze-td5146777.html
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
