[Qgis-user] Trouble projecting on the fly
Sharon Selvaggio
ssitalian at comcast.net
Thu Feb 26 20:55:42 PST 2015
Still struggling.... I am attaching the info from the prj file and the
extent info from the metadata for each shapefile:
I noticed that the PROJCS is labeled as "Custom"...could that be
confusing QGIS?
Or is it because one is a projected CRS and one is a geographic CRS?
*_or_state_boundary.prj_*
PROJCS["Custom",
GEOGCS["GCS_North_American_1983",
DATUM["D_North_American_1983",
SPHEROID["GRS_1980",6378137.0,298.257222101]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Lambert_Conformal_Conic"],
PARAMETER["False_Easting",1312335.958],
PARAMETER["False_Northing",0.0],
PARAMETER["Central_Meridian",-120.5],
PARAMETER["Standard_Parallel_1",43.0],
PARAMETER["Standard_Parallel_2",45.5],
PARAMETER["Central_Parallel",41.75],
UNIT["Foot",0.3048]]
xMin,yMin 183871.74,88600.9 : xMax,yMax 2345213.24,1675042.97
*_CKUWR.prj_*
xMin,yMin -123.522,43.356 : xMax,yMax -121.714,45.4562
Help very much appreciated.
On 02/24/2015 07:26 AM, Andre Joost wrote:
> Am 24.02.2015 um 07:55 schrieb Ramon Andiñach:
>>> On 24 Feb 2015, at 14:06, Sharon Selvaggio
>>> I start by setting my project CRS.
>> And make sure OTF is on.
> You have no choice of setting a project CRS if OTF is off.
>>> But when I do this with files that have originated from two
>>> different sources with different native projections (or no
>>> projection?) they still do not align.
>> Different sources or different layer CRS shouldn't matter.
> Shapefiles without .prj file are still existing in the world.
>> There is an option mentioned previously so that you can set how QGIS
>> handles layers that it can't tell what the CRS is.
> Settings -> Options, CRS Tab, CRS foor new layers.
>> If you can point us at the files you're using - or excerpts from them
>> - then we might be able to understand where the problem is better.
> Or tell us the extent of every layer, as reported by Rightclick ->
> Properties, metadata tab.
>> 1. On a side note. Do not use the Google maps/satellite images to
>> check if your layers are in the right place unless you understand the
>> gotchas in using that service.
> I don't agree with that.
> If some layers come up on the wrong part of the Earth, it is a good
> reference to see which layers are right and which are wrong.
> Natural Earth shapefiles can be a reference as well.
> Greetings,
> André Joost
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150226/f33df382/attachment.html>
