[Qgis-user] Trouble projecting on the fly
Andre Joost
andre+joost at nurfuerspam.de
Fri Feb 27 07:34:20 PST 2015
Am 27.02.2015 um 05:55 schrieb Sharon Selvaggio:
> I noticed that the PROJCS is labeled as "Custom"...could that be
> confusing QGIS?
No, only the parameters matter.
> Or is it because one is a projected CRS and one is a geographic CRS?
Should be no problem with OTF enabled.
> *_or_state_boundary.prj_*
> PROJCS["Custom",
> GEOGCS["GCS_North_American_1983",
> DATUM["D_North_American_1983",
> SPHEROID["GRS_1980",6378137.0,298.257222101]],
> PRIMEM["Greenwich",0.0],
> UNIT["Degree",0.0174532925199433]],
> PROJECTION["Lambert_Conformal_Conic"],
> PARAMETER["False_Easting",1312335.958],
> PARAMETER["False_Northing",0.0],
> PARAMETER["Central_Meridian",-120.5],
> PARAMETER["Standard_Parallel_1",43.0],
> PARAMETER["Standard_Parallel_2",45.5],
> PARAMETER["Central_Parallel",41.75],
> UNIT["Foot",0.3048]]
If I load a file with that projection, it gets identified as
EPSG:2992 NAD83 / Oregon Lambert (ft)
> xMin,yMin 183871.74,88600.9 : xMax,yMax 2345213.24,1675042.97
That is the extent of whole Oregon in that projection.
> *_CKUWR.prj_*
This gets identified as EPSG:4269 NAD83
> xMin,yMin -123.522,43.356 : xMax,yMax -121.714,45.4562
An area south of Portland.
> Help very much appreciated.
I have started with a project in EPSG:3857, added Openstreetmap
background from the openlayers plugin, and the extent points as
delimited text with the EPSG codes above.
Make sure that QGIS prompts you for CRS of new layers, and delete .qpj
files that may come from earlier tries you did.
HTH,
André Joost
