[Qgis-user] Coordinate Display
Willem Buitendyk willem at pcfish.ca
Fri Jan 9 15:07:46 PST 2015
Hi Nicolas,
Thanks for the response but I think I’m not explaining myself clearly.  I have a map that I want to keep in the BC Albers (meters) projection but I also want to have the coordinate display show in decimal degrees.  It seems with QGIS I currently cannot have it both ways.  In Arcmap or Manifold, I am able to keep the map projection and display mouse coordinates as latitude and longitude or decimal degrees regardless of projection.
Willem Buitendyk
> On Jan 9, 2015, at 1:43 PM, Nicolas Cadieux <nicolas.cadieux at archeotec.ca> wrote:
> Hi,
> Go to the projects properties\CRS and filter using "csrs".  You will find all the projections used in Canada.  Projection with " Atlas " is the name usually gives us a look we are familiar with.  Make sure you have CRS on the fly activated.
> I have a google group called QGIS Canada for this type of question relating to Canada.  You are welcome to join.
> Nicolas Cadieux M.Sc.
> Les Entreprises Archéotec inc.
> 8548, rue Saint-Denis Montréal H2P 2H2
> Téléphone: 514.381.5112  Fax: 514.381.4995
> Le 2015-01-09 16:03, "swaxolez [via OSGeo.org]" <[hidden email] <x-msg://8/user/SendEmail.jtp?type=node&node=5180876&i=0>> a écrit :
> If I load a map with a single layer with a projection such as BC Albers and then want to display latitude and longitude coordinates while panning and moving around how do I do this?
> I tried changing the map units in Project Properties but the resulting latitude and longitude is grossly incorrect.  I can turn on CRS and then reproject into something like EPSG:4326 and then my latitude and longitude work properly but then my map data is skewed due to the reprojection and not displaying the way I'd like to see it.
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Coordinate-Display-tp5180869.html <http://osgeo-org.1560.x6.nabble.com/Coordinate-Display-tp5180869.html>
> To start a new topic under Quantum GIS - User, email [hidden email] <x-msg://8/user/SendEmail.jtp?type=node&node=5180876&i=1>
> To unsubscribe from Quantum GIS - User, click here <applewebdata://C569B307-8AA7-4FBB-9D2F-543205874A42>.
> NAML <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: Coordinate Display <http://osgeo-org.1560.x6.nabble.com/Coordinate-Display-tp5180869p5180876.html>
> Sent from the Quantum GIS - User mailing list archive <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at Nabble.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150109/7ac5452b/attachment.html>
