[Qgis-user] export coordinates in diferent src
daniel pinto daniel.ar.pinto at gmail.com
Sat Jan 10 03:48:57 PST 2015
Thanks youuu!!! Done!! ;)
Em 10/01/2015 12:31, "Andre Joost" <andre+joost at nurfuerspam.de> escreveu:
> Am 10.01.2015 um 11:17 schrieb daniel pinto:
>> hello i have a poligon wit 120 vertices and i have the coordinates in wgs
>> 84 espg 4326
>> i need the same coordinates im the atribute table in utm 33s espg 32733
>> is it possible to export them in this src and add to the atribute column
>> witout usic coordinate capture and doing it one by one???
> You have to save your layer using rightclick, Save As... to another name
> and EPSG:32733, and add the result to the canvas. From that, you can export
> the vertex coordinates to CSV with the mmqgis plugin.
> For a polygon, you will not get the coordinates into the attribute table,
> because the whole polygon has only one row in the attribute table. You can
> get coordinates in the attribute table only for point layers.
> HTH,
> André Joost
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150110/108baf70/attachment.html>
