[Qgis-user] Re : Edit print composer
Matt Boyd mattslists at gmail.com
Tue Jan 13 14:48:25 PST 2015
Thanks junior,
This is what I'm doing at the moment. What I'd like is to be able to load
the locked items in the print composer to the main window.
Sorry if I wasn't clear.
On 13/01/2015 7:02 pm, "Junior" <delazj at gmail.com> wrote:
> Hi Matt,
> Once you have activated all the layers that should be displayed in your
> print composer, select the map item inside your print composer and check
> the option "lock layers for map item" in the properties tab.
> More info can be found below "Composer Items" chapter in this link
> http://docs.qgis.org/2.6/en/docs/user_manual/print_composer/print_composer.html
> Envoyé depuis mon HTC
> ----- Reply message -----
> De : "Matt Boyd" <mattslists at gmail.com>
> Pour : "qgis-user" <qgis-user at lists.osgeo.org>
> Objet : [Qgis-user] Edit print composer
> Date : mar., janv. 13, 2015 06:02
> Hi QGISers,
> I've got a few different print composers in the same project and it's
> slightly painful to go back and turn layers on/off when I want to edit one
> of them.
> Is there an easy way to turn on/off the layers in a particular print
> composer automagically?
> THanks
> Matt
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150114/1b58eb18/attachment.html>
