[Qgis-user] Re : Edit print composer
Matt Boyd mattslists at gmail.com
Wed Jan 14 14:11:01 PST 2015
On Thu, Jan 15, 2015 at 1:42 AM, Alexandre Neto <senhor.neto at gmail.com>
wrote:
> How cool can that be?
very very cool, thanks.
Matt Boyd
> Alexandre Neto
> On Wed, Jan 14, 2015 at 2:48 AM, Matt Boyd <mattslists at gmail.com> wrote:
>> thanks Andreas,
>> every time I turn around there's something new in QGIS (which is great).
>> just browsing through the manual, are you able to give me some tips on
>> how to enable / use this functionality.
>> On Wed, Jan 14, 2015 at 10:06 AM, Andreas Neumann <a.neumann at carto.net>
>> wrote:
>>>  Hi,
>>> It isn't directly possible.
>>> However, starting with QGIS 2.6 you can use the visibility presets
>>> (bookmarks of combinations of layer visiblities) which can be used directly
>>> in both the main window and the print composer. So you can switch very
>>> quickly in both windows.
>>> Andreas
>>> On 13.01.2015 23:57, drruddy gmail wrote:
>>>  Hello Matt,
>>>  I don’t think that’s possible. Would be interested to know if it can
>>> be done but I’ve only been able to change layers in composer from map
>>>  MR
>>> On 13 January 2015 at 22:48:42, Matt Boyd (mattslists at gmail.com) wrote:
>>>  Thanks junior,
>>> This is what I'm doing at the moment. What I'd like is to be able to
>>> load the locked items in the print composer to the main window.
>>> Sorry if I wasn't clear.
>>> On 13/01/2015 7:02 pm, "Junior" <delazj at gmail.com> wrote:
>>>>  Hi Matt,
>>>> Once you have activated all the layers that should be displayed in your
>>>> print composer, select the map item inside your print composer and check
>>>> the option "lock layers for map item" in the properties tab.
>>>> More info can be found below "Composer Items" chapter in this link
>>>> http://docs.qgis.org/2.6/en/docs/user_manual/print_composer/print_composer.html
>>>>  Envoyé depuis mon HTC
>>>> ----- Reply message -----
>>>> De : "Matt Boyd" <mattslists at gmail.com>
>>>> Pour : "qgis-user" <qgis-user at lists.osgeo.org>
>>>> Objet : [Qgis-user] Edit print composer
>>>> Date : mar., janv. 13, 2015 06:02
>>>> Hi QGISers,
>>>> I've got a few different print composers in the same project and it's
>>>> slightly painful to go back and turn layers on/off when I want to edit one
>>>> of them.
>>>>  Is there an easy way to turn on/off the layers in a particular print
>>>> composer automagically?
>>>>  THanks
>>>> Matt
>>>  _______________________________________________
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150115/0ae1d5c5/attachment.html>
