[Qgis-user] Processing: how to use input parameter in "Select by expression"
Andreas Neumann
a.neumann at carto.net
Thu Jan 15 21:46:14 PST 2015
Along the lines - I am generally unsure how I can connect input
parameters in algorithms. Sometimes they magically appear in the
algorithm to be chosen. Sometimes they don't. Is there a general way to
connect input parameters to be used as variables for algorithm parameters?
Thanks,
Andreas
On 16.01.2015 06:34, Andreas Neumann wrote:
> Hi,
> In QGIS processing I would like to do the following:
> Input Parameters:
> - Vector Layer
> - Numeric input parameter (year)
> Use the "select by expression" algorithm.
> Question: how can I use the value of the "year" input variable to be
> used in the expression. Is there a special syntax to retrieve the
> values of input parameters?
> Thanks a lot!
> Andreas
> Qgis-user mailing list
