[Qgis-user] Cutting lines with a polygon boundary
Zoltan Szecsei zoltans at geograph.co.za
Sun Jan 25 12:43:41 PST 2015
On 2015/01/25 20:23, Andre Joost wrote:
> Am 25.01.2015 um 13:51 schrieb Zoltan Szecsei:
>> So, does anyone know of a way to efficiently cut features in multiple
>> layers using a polygon, and then to be able to select the pieces
>> (multiple layers) that are either inside or outside the polygon, and
>> then delete them?
> Disregarding the "multiple":
> "Vector -> Geoprocessing -> Clip" deletes the items outside the polygon
Nope, doesn't. - In my first point I said: */Vector Geometry Processing
Clip, but it wants to extract the data inside the polygon and create a
new file with the extracted data. (To be expected)
/*but meant: */Vector-> GeoProcessingTools-> Clip, but..... /*(my bad,
apologies)*/
/*It does not delete, it clips them out into a new layer/- which is not
what I'm hoping to achieve./*/
Thanks for the thought anyway, though.
Regards,
Zoltan*/
> "Vector -> Geoprocessing -> Difference" deletes the items inside the
> polygon
> You would have to do it for every layer you want to be cut, the
> dialogue box will stay open after cutting. If the polygon layer
> contains just one polygon, no selecting is necessary.
> BTW: make sure all layers share the same CRS (i.e. turn
> on-the-fly-reprojection off)
> HTH,
> André Joost
> Qgis-user mailing list
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
P.O. Box 7, Muizenberg 7950, South Africa.
Mobile: +27-83-6004028
Fax:    +27-86-6115323     www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150125/d8823d8b/attachment.html>
