[Qgis-user] Cutting lines with a polygon boundary
Randal Hale rjhale at northrivergeographic.com
Sun Jan 25 13:45:23 PST 2015
What if you unioned the Layers with the polygon - then deleted the
original polygon from the new layer? I don't know if that would work -
every layer would then need to be touched once to clip and then again to
delete the original polygon...but you would have a break then at each
intersection if I understand this correctly.
Randy
On 01/25/2015 03:43 PM, Zoltan Szecsei wrote:
> On 2015/01/25 20:23, Andre Joost wrote:
>> Am 25.01.2015 um 13:51 schrieb Zoltan Szecsei:
>>> So, does anyone know of a way to efficiently cut features in multiple
>>> layers using a polygon, and then to be able to select the pieces
>>> (multiple layers) that are either inside or outside the polygon, and
>>> then delete them?
>> Disregarding the "multiple":
>> "Vector -> Geoprocessing -> Clip" deletes the items outside the polygon
> Nope, doesn't. - In my first point I said: */Vector Geometry
> Processing Clip, but it wants to extract the data inside the polygon
> and create a new file with the extracted data. (To be expected)
> /*but meant: */Vector-> GeoProcessingTools-> Clip, but..... /*(my bad,
> apologies)*/
> /*It does not delete, it clips them out into a new layer/- which is
> not what I'm hoping to achieve./*/
> Thanks for the thought anyway, though.
> Regards,
> Zoltan*/
>> "Vector -> Geoprocessing -> Difference" deletes the items inside the
>> polygon
>> You would have to do it for every layer you want to be cut, the
>> dialogue box will stay open after cutting. If the polygon layer
>> contains just one polygon, no selecting is necessary.
>> BTW: make sure all layers share the same CRS (i.e. turn
>> on-the-fly-reprojection off)
>> HTH,
>> André Joost
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Zoltan Szecsei PrGISc [PGP0031]
> Geograph (Pty) Ltd.
> GIS and Photogrammetric Services
> P.O. Box 7, Muizenberg 7950, South Africa.
> Mobile: +27-83-6004028
> Fax:    +27-86-6115323www.geograph.co.za
Randal Hale
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale     http://about.me/rjhale
http://www.northrivergeographic.com/introduction-to-quantum-gis
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150125/6e8b944a/attachment.html>
