[Qgis-user] Fwd: QGIS crash on loading projects
Matt Boyd mattslists at gmail.com
Mon Jan 26 22:32:15 PST 2015
Complete reinstall third time lucky, QGIS runs. It still crashes when I try
to open an older project so I'm back to where I was this morning.
I would really appreciate knowing if there is a log file generated or how
to create one?
On Tue, Jan 27, 2015 at 4:05 PM, Matt Boyd <mattslists at gmail.com> wrote:
> On Tue, Jan 27, 2015 at 11:17 AM, Nicolas Cadieux <
> nicolas.cadieux at archeotec.ca> wrote:
>> Hi,
>> Personally this is what I would do.
>> Completely purges Qgis from your system.  (Delete plugin directories, AND
>> the Qgis registry keys.) Reboot.
>> I would install Qgis 2.6.1 using the OSGEO install.
> I followed these steps. My install was already done via osge064w and
> uninstalling was a little tricky.
> I removed the directories and the registry entries.
> I then reinstalled QGIS via the express installer.
> QGIS wouldn't start giving an error about jvm.dll missing from my computer.
> I manually selected the java install via the advanced option, jvm is
> installed and in a subfolder in C:\osgeo4w64
> I suspect it's a path problem, working on this.
> I would make sure that all mapped drive are properly remapped with the
>> proper passwords, I would install the open layer plugin and wms or other
>> data servers. Make sure the symbols are reinstalled if you had new ones and
>> also make sure the .svg symbol images are well mapped.
>> If the problem persists, I would repurge Qgis, install and older version
>> and try again.
>> Finally, i would then start looking at the project files with a text
>> editor to try to  understand the problem. I is likely the crash is cause by
>> a layer that cannot be opened and that this layer depends on a plugin like
>> openlayer, a mapped drive, wms servers... That would be my guess.
>> Nicolas Cadieux M.Sc.
>> Les Entreprises Archéotec inc.
>> 8548, rue Saint-Denis Montréal H2P 2H2
>> Téléphone: 514.381.5112  Fax: 514.381.4995
>> Le 2015-01-26 18:16, "Matt Boyd [via OSGeo.org]" <[hidden email]
>> <http:///user/SendEmail.jtp?type=node&node=5183862&i=0>> a écrit :
>> Thanks Lene,
>> I tried that on a 3 projects this morning with no change to the
>> behaviour. I've had 2.6.1 for a while now and these projects opened in that
>> early last week.
>> I've also tried loading older projects that are still in 2.0, 2.2, and
>> 2.4 format and the same thing happens.
>> Most of my projects are on a network drive and I've managed to get a step
>> further by copying those project files to a local drive. I then get the
>> "handle bad layers" dialog, then qgis crashes. I need to dig a little to
>> see if this is a problem in case someone has moved some of the layers the
>> dialog is referring to but this hasn't caused a crash before.
>> Is this behaviour logged anywhere?
>> Thanks
>> Mat
>> On Tue, Jan 27, 2015 at 9:58 AM, Lene Fischer <[hidden email]
>> <http:///user/SendEmail.jtp?type=node&node=5183855&i=0>> wrote:
>> Please first update to 2.6.1.
>> If you have your crashed projects – you also have projects named with a
>> .qgs~. Rename this project and delete the ~  and open it as usual.
>> A lot of my students had the same problem last week – but only the ones
>> who had forgotten to update to 2.6.1
>> Hope this can help you.
>> Regards
>> *Lene Fischer*
>> Associate Professor
>> *Department of Geosciences and Natural Resource Management*
>> University of Copenhagen
>> MOB <a href="tel:%2B45%2040115084" value="+4540115084" target="_blank">+45
>> 40115084
>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5183855&i=1>
>> [image: cid:image001.gif at 01D03029.2F3EC6A0]
>> *Fra:* [hidden email]
>> <http:///user/SendEmail.jtp?type=node&node=5183855&i=2> [mailto:[hidden
>> email] <http:///user/SendEmail.jtp?type=node&node=5183855&i=3>] *På
>> vegne af *Matt Boyd
>> *Sendt:* 26. januar 2015 23:29
>> *Til:* qgis-user
>> *Emne:* [Qgis-user] Fwd: QGIS crash on loading projects
>> Just a bump to this question, does anyone know how to enable logging or
>> find the log file? I really don't want to have to re create all my project
>> files and I can't get any of the my old projects to open.
>> On Fri, Jan 23, 2015 at 3:09 PM, Matt Boyd <[hidden email]
>> <http:///user/SendEmail.jtp?type=node&node=5183855&i=4>> wrote:
>> On Fri, Jan 23, 2015 at 2:58 PM, Nicolas Cadieux <[hidden email]
>> <http:///user/SendEmail.jtp?type=node&node=5183855&i=5>> wrote:
>> Hi,
>> If you had and "openlayer" opened (like google earth or bing map), but
>> but did not reinstall the plugin, it can crash.  Try installing that plugin
>> and see what happens...
>> Nope, that doesn't help.
>> Téléphone: <a href="tel:514.381.5112" target="_blank">514.381.5112  Fax:
>> <a href="tel:514.381.4995" target="_blank"> 514.381.4995
>> Le 2015-01-22 22:46, "Matt Boyd [via OSGeo.org]" <[hidden email]
>> <http://user/SendEmail.jtp?type=node&node=5183270&i=0>> a écrit :
>> woops, forgot,
>> windows 7 64 bit,
>> qgis 2.6 installed via osgeo4w64
>> On Fri, Jan 23, 2015 at 2:45 PM, Matt Boyd <[hidden email]
>> <http://user/SendEmail.jtp?type=node&node=5183269&i=0>> wrote:
>> Hi QGISers,
>> for some reason today I can't load saved QGIS projects. QGIS crashes at
>> abour 95% loaded with no information in the notification about why.
>> I've tried reinstall from osgeo4w64, reboot, start from command line,
>> disabling all plugins.
>> Where's the log file kept and is there a way to enable logging from the
>> osgeo cl window in windows 7?
>> About the only thing that's different today is a few updates, one of them
>> being a .NET windows update.
>> Thanks
>> Matt
>> Qgis-user mailing list
>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5183269&i=1>
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> *If you reply to this email, your message will be added to the discussion
>> below:*
>> http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183269.html
>> To start a new topic under Quantum GIS - User, email [hidden email]
>> <http://user/SendEmail.jtp?type=node&node=5183270&i=1>
>> To unsubscribe from Quantum GIS - User, click here.
>> NAML
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>> View this message in context: Re: QGIS crash on loading projects
>> <http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183270.html>
>> Sent from the Quantum GIS - User mailing list archive
>> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at
>> Nabble.com.
>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5183855&i=6>
>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5183855&i=7>
>> discussion below:
>> http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183855.html
>> <http:///user/SendEmail.jtp?type=node&node=5183862&i=1>
>> NAML
>> View this message in context: Re: Fwd: QGIS crash on loading projects
>> <http://osgeo-org.1560.x6.nabble.com/QGIS-crash-on-loading-projects-tp5183268p5183862.html>
>> Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150127/387a099a/attachment.html>
