[Qgis-user] WFS-T update to geoserver fails
Richard Duivenvoorde rdmailings at duif.net
Tue Jan 27 06:05:33 PST 2015
is it possible to use try out another wfs-t client to talk to your
Boundless geoserver (for example a simple openlayers client)?
If that one is also failing/hanging then you can point your energy into
the Geoserver.
With Openlayers and using firefox with firebug (javascript debugging)
you can easily extract the wfs-t requests and responses and rerun them
using the extention 'poster'.
What I've seen before with a geoserver wfs-t was that the first edit
went wrong (because of the missing of an id or so) and then subsequent
edits were ok (though that was with an Oracle-layer....).
You should not be able to 'hang' geoserver using whatever client, you
have to look into the logs of geoserver to see what happens. Do you have
a lot of layers and is geoserver updating it's cache or so?
Geoserver has a lot of debug levels, try to raise the debuglevel to see
what comes in at geoserver?
As I've used QGIS in combi with WFS-T before ad your osgeo live setup is
succesfull, my first guess is the Boundless Geoserver, but I could be wrong.
Regards,
On 27-01-15 14:16, emmexx wrote:
> I load a wfs-t layer hosted on a geoserver server and add or modify a
> feature.
> When I save the layer, qgis timeouts, the layer is not updated on the
> server and I have to restart geoserver in order to be able to load it
> again in qgis (and elesewhere too).
> The qgis error is:
> Could not commit changes to layer xxx
> Errors: ERROR: 1(s) feature not added
> Provider errors:
>   Empty response
> I found something similar described here:
> [[http://gis.stackexchange.com/questions/115471/qgis-wfs-error-could-not-commit-changes-to-layer]]
> [[http://jira.codehaus.org/browse/GEOS-6059]]
> Trying to understand what was wrong in the qgis call (update of a
> feature or new feature added) I used netTool. This program has a tunnel
> feature that acts as a MITM between an application and a remote server.
> So I changed the wfs address in qgis from:
> http://mywebsite:8080/geoserver/wfs to
> http://localhost:7000/geoserver/wfs and set netTool to tunnel to
> I updated a feature value, saved and to my great surprise everything
> worked fine.
> After filing a bug in qgis I was suggested to try to connect to another
> geoserver. I started osgeo live 8 on another pc on my local network,
> from my desktop I started qgis, added a WFS layer from geoserver on
> osgeo live 8, updated a feature and everything worked fine.
> So I'm asking here for help.
> I asked for help on the geoserver mailing list but since I'm using the
> boundless opengeo versione, they can't help.
> I just want to understand if this is a geoserver only problem or if it
> derives from the interaction of qgis and geoserver.
> Why does netTool makes everything work fine?
> Why can a call from qgis hang geoserver (the wfs service of...)?
> Any help would be appreciated.
>     maxx
> QGIS version    2.6.1-Brighton    QGIS code revision    exported
> Compiled against Qt    4.8.5    Running against Qt    4.8.5
> Compiled against GDAL/OGR    1.11.0    Running against GDAL/OGR    1.11.0
> Compiled against GEOS    3.3.8-CAPI-1.7.8    Running against GEOS
> 3.3.8-CAPI-1.7.8
> PostgreSQL Client Version    No support.    SpatiaLite Version    4.0.0
> QWT Version    5.1.1    PROJ.4 Version    480
> QScintilla2 Version    2.6.1
> Geoserver is version 2.5 snapshot installed from boundless opengeo suite
> 4.1
> Qgis-user mailing list
